  1. In the navigation pane, expand Configuration > IPv6.
  2. Select IPv6 PIM.
  3. Select the Neighbor Secondary Address tab.
Neighbor Secondary Address Field Descriptions
Use the descriptions in the following table to use the Neighbor Secondary Address tab.
Name
Description
IfIndex
Shows the slot and port number or VLAN ID of the interface used to reach this PIM neighbor.
Type
Shows the address type of this PIM neighbor.
Primary
The primary IPv6 address of this PIM neighbor.
SecAddress
The secondary IPv6 address of this PIM neighbor.
